805 "pin" mod to 800FSB?
mavalpha
Thinking about picking up a spare 805 combo soon, but odds are I'll just slap it into my Intel G965 board. I'll definitely do the voltage boosts as well, but I'm trying to find out how to hardwire the 805 to a 200MHz FSB and run it at 4GHz in a non-OC board.
I don't think 805 would run it at 4ghz even if you add voltage with regular air cooling...
I could get my 805 at 3.8ghz but that's with 1.6volts originally 1.3375volts....
Temperature quickly rises to 80C with my good air cooler...
At 4 ghz it will not even post...
I'm sure your motherboard can change fsb on the fly... Why do you have to mod it? If your motherboard can take Pentium D it has option to change it to 800fsb even if it's non overclocking motherboard...
yeah, 4ghz on that is really a stretch. i remember ever since the p3 days, i'd occasionally help out by finding the datasheet from intel's website and draw out the pins to connect. but i've gotten lazier over the years ;) goto intel's website and look up the datasheet for the cpu. you're going to want to look at the table for bsel settings, and figure out what to drop to ground (lo resistance) or possibly what to insulate (hi resistance).
