Ah should've specified in orig post. I'm looking for gigabit.What are the requirements bandwidth wise?
yeah, you've got to pay to play... with Cisco... so Dell/HP is your best bet for keeping it on the cheap. You'll get some SoHo recommendations I'm sure but I prefer to sacrifice bandwidth for functionality/longevity. Whats your budget look like? What are you using the switch for?Ah should've specified in orig post. I'm looking for gigabit.
Still looking at what an appropriate budget should be for such a thing. I'm sitting more in the $200-$300 range (like I said, used is acceptable to me), and I'm looking to to link aggregation for a gigabit network (partly as testing as a lab setup, and hopefully to improve network transfers for my fileservers).Whats your budget look like? What are you using the switch for?
Looking at the 2800 line, these really do seem like what I'm looking for.. and relatively in my budget range when looking on ebay. Thanks for the input!HP 2824, love it
Alot of the guys around here love that switch, so it has a good user base here. Seems pretty solid to me. If I wasn't so lucky idd probably go with it honestly.Looking at the 2800 line, these really do seem like what I'm looking for.. and relatively in my budget range when looking on ebay. Thanks for the input!
Wow! Even cheaper than the HP ones and have 802.3ad for ~$100! These seem pretty comparable to the HPs.. anyone know what the HPs have over the dells to make it worth the extra cash?Dell 28XX I have a few 2808s out in the wild work great.
HP is WAY more solid than Dell as far as networking goes. They have a better track record and have a much larger user base when it comes to networking platforms. Idd EASILY go with HP over Dell. Ive used both back in the day, and the dell had failed ports well before the HP did if that means anything to you. This was in a controlled DC environment too, so same environmental conditions.Wow! Even cheaper than the HP ones and have 802.3ad for ~$100! These seem pretty comparable to the HPs.. anyone know what the HPs have over the dells to make it worth the extra cash?
Remember, I said back in the day(which was like 7 years ago).. things may have changed with designYikes! Well then I'll stick to the HP's. I'll keep looking out for a good price on ebay or elsewhere for the 2840 which looks like it would be great for me. Thanks for all of the input everyone (and quick responses!)
