MMOs, Starcraft, and Battlefield 3 when it comes out
800 total but willing to goto 900 if needed
3) Where do you live?
Phoenix Arizona
CPU, RAM(I would like 8 Gigs), Motherboard, Power Supply, HD(I'm thinking a 2TB drive), GPU(1 GPU is fine for now, another in fall for BF3?), and maybe a case if I can't reuse my current one.
This info is for the power supply:
I plan on getting these upgrades later this year - a SSD, one more 2TB drive, TV tuner, sound card, and maybe another GPU for SLI/xfire so I can play Battlefield 3 on decent settings.
I would like to reuse my Lian Li case if possible. LIAN LI PC-V1000BPlus II http://www.newegg.com/Product/Product.aspx?Item=N82E16811112058
DVD/RW http://www.newegg.com/Product/Product.aspx?Item=N82E16827118030
6) Will you be overclocking?
No overclocking
Currently 20in 1680x1050 but planning on 24in 1920x1200 in the fall
In the next two weeks
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
Onboard sound and possibly Xfire/SLI
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Yes, Win7 64bit
Phoenix Arizona
No overclocking
Yes, Win7 64bit
