~$800 Bucks, what to do? :)
iRoNeTiK
Vodka Martinis are for the Weak
First off, thank you IRS for the tax refund haha.
Anyway, I currently have a FX-55 @ 3 ghz and DDR500 ram and looking for an upgrade.
This means a new CPU, Motherboard, and RAM to OC on aftermarket Air Cooling. I think my Corsair 620watt will be fine? It has three 12 volt rails @ 18 amps, but isn't a single rail the way to go these days?
I was looking at the X38 (ASUS) or 780i (eVGA) motherboard and maybe wait for the X48 chipset. What do you think?
I would like something I could at least upgrade the CPU/RAM once before doing a major overhaul again, so probably get a motherboard that supports 1600 Mhz FSB. For example, my 939 system I went from a 3000+ Venice to a FX-55 San Diego w/o replacing motherboard or RAM.
The other question I have is what RAM? DDR2 is so cheap, I can get a nice 4gb kit @ 1066 compared to a 1066 DDR3 kit (380 bucks for 2 gigs?!) haha! I know the DDR3 would be more future proof, but I doubt the prices will drop anytime soon and the DDR2 prices will probably increase sometime soon so right now I'm thinking a nice high end (g.skill?) set of DDR2 4gb (2x2gb) memory, unless someone can convince me otherwise :)
As far as the CPU, If money grew on trees I would get the QX9650. So I'm looking for something mid-range that I can OC beyond a more expensives CPU rated speeds. Dual or Quad core, I don't have a preference, I just game and chit chat, no video or music editing or 3d rendering, if that makes a difference, So maybe a nicer dual core processor would do me justice?
As said in the subject, I have 800 dollars, but this can be somewhat flexible (lets say 1k MAX), doesn't need to be exact, but the cheaper the better :)
CLIFFS:
Looking for CPU/MOBO/RAM, ~$800
Intel Dual or Quad
DDR2 or DDR3?
X38/X48 or 780i?
I'd really have to say good luck going for the new chipsets on $800 unless you got a lot of spare parts (cases, decent heat sinks, harddrives), if you do, then it's surely doable.
Though, E8400s are cheap for the performance, and 4gb of DDR2 is well under $100 now ($55 AR at times), DDR3 out of the question for that price point. As far as 620HX I use it myself, it's a beast. It's fine. Can run anything out (at least single video card configs).
You are referring to selling spare parts? If so, I can do that to a limited extent, wouldn't be a big impact.
Yeah, a lot of people around here talking about the g.skill :) Thanks for the links
DDR3 not that bad as it used to be , high performance plat edition OCZ DDR3 - 1333 - 2 Gbs
for 250$ compared to 70$ DDR2 - 800 , however you can go Intel DX38BT mobo for 230$ vs Asus X38 280$
this somehow makes the ram 250$ ddr3 vs 120$ ddr2... double price!
Much more than double, considering price per gig. 4GB DDR2 for *WELL* under $100 vs 2GB DDR for *WELL* over $250.
Would be better in the long run to upgrade now, wait for prices to drop and part it out.
And I wasn't really referring to selling of parts but more like reusing parts, IE: reusing a case, not needing to buy an aftermarket cooler, no need for optical drives, etc. To keep costs cheap.
I tend to always build a whole new rig (minus a few tidbits) each time, so $800 is often never enough for me, got my whole P35/E8400 combo setup with case and PSU for well under $1000 if all rebates make it through ($110~ in MIR), so that's good I guess.
Also picked up some speakers and a 24" LG that I didn't count, but hey.
First of all ask yourself if you really need a new machine? Is your old machine isn't letting you do what you need to do at the moment? I mean if you only surf the web and play games once and awhile, your machine seems to be good enough for that.
Save your money and get yourself a better machine within a year because price will drop dramatically. DDR3 is too new and too expensive at the moment.
If any of us asked that question, would we be here now? :D
I've got a 939 Opteron 185, 2GB DDR, and an Asus A8R32-MVP Deluxe. I just bought the Gigabyte GA-X38-DS4 ($207), 4GB G-Skill GSK F2-6400CL4D-4GBPK ($110), e8400 ($212). Prices include shipping and tax. I am also reusing all my parts. For your budget, you could go quad core, or upgrade your video card too. Or, you could save the extra money. :eek:
I would be using all of my old parts (which are good) so that will keep the ~800 dollars for the CPU/Mobo/RAM.
Well, I never really need to upgrade hehe but I will :)
I think I will wait a few more months and probably get some more money but now I have a sense for what I need.
Thanks for the advice and links.
e8400 = $230
Asus P5K-E (or other mid rand P35 board) = $140
2x1Gb ddr2 1000 = $70
Total $440+
Save $350 for when the Q9450's come out, so you can upgrade to one of those. OR get a new/better videocard?
I just don't see the point of spending getting an X38 or other highend motherboard. The P35's are stable and fast motherboards and $100 less. No real reason for the extra $100.
You can get the 8400 from microcenter for atound $190ish.
I have used the Asus p5k (ddr2 version non wifi) and it oc's like a champ.
I have g.skill 2x2gb 800mhz ram and I like it with my e6600 (tho that 1000mhz ram is nice stuff and isn't overkill with the 8400.
No need for x38 now, imo and as others have said. Get the p35. The gigabyte p35-ds3 can be had for under $100 and can OC pretty well.
Intel Dual or Quad
DDR2 or DDR3?
X38/X48 or 780i?
E8x00. Im waiting for the E8200 since it seems they can make it to 4GHz as well as the others. ~$200
DDR2 definitely. DDR2-800 4GB for under $100.
None of the above. P35. Cheap ABIT or Gigabyte are under $100.
So thats around $400 total. Save the rest.
Is this for gaming? If so, put as much money as you can on the graphics card. I spent about your amount for my C2D. I am very happy with it. If I'd do it again with that budget i'd just get an e8400 and a decent cpu cooler to bring it up to 4Ghz.
I would recommend a e8400, 4gb of some crucial or gskill ddr2, and a gigabyte or abit p35 board, that should come out to somewhere around $350-$450
You already have a pretty nice setup.. good psu, good gpu...
with the extra $400.. get maybe a mini-fridge next to your desk or something.. nice keyboard/mouse... etcetera...
If you really want to spend that extra $400 on your computer and do a lot of gaming, maybe upgrade your gpu to a g92 or 3870x2 or something...
