8 pin 12v CPU power extention?
newls1
Where can I find 1? I've looked @ newegg, crazypc, ZZF, to no avail. HELP:D
just so you know, these things don't do anything except create a fire hazard. if your PSU doesn't have enough amps on the 12v line, an adapter isn't going to change anything. if it does, the adapter isn't needed.
I'd assume he is in the same boat as me. Quality PSU, mounted underneath the board so an extension is in order to reach the plug.
you got it!. To the person who said my PSU might be low on amps, well it has 60A on a single 12v rail;) . Thanks to PCP&C
aha! in my sleepy mind i thought you were talking about one of those 4 to 8 pin adapters... errr i need to go to bed
anyway how do you like that PSU? my antec 550 watt is choking and wheezing on this overclocked C2D / 8800 thing. An upgrade may be in order...
as with ANY PCP&C PSU---------------------------awesome
Just FYI, I had a 20pin ATX extension and 8 pins in a row will match up to the 8pin 12v connection. I just cut each end down to those 8 pins and it works wonderfully.
