Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Is it possible to set a VM to only have a single core and have that single VM core use the power of multiple cores? Running a program that will only use one core and I'm trying to find a way to make it work better.
I guess I don't get that AndyWolf post. Because the isues are all based on licensing. SQL Express is limited to 1 socket. Trying to add multiple sockets rather than cores to a single socket in an era where so many programs are limited by socket rather than core is dumb.
His point is that by default if you give a VM 4 vCPUs it's exposed to the guest as four sockets, not a single socket with four cores. So you can "fool" the guest and apps by changing that default.
