I am not very knowledgeable when it comes to computers but here is my problem that I have not found the solution to anywhere. I just bought a RADEON HD 4670 and put it in my computer, following all the steps and so on. I installed the drivers on the CD which came with CCC 8.8, but the manual suggested looking for updates. So I go to the ati website and download version 8.9 and attempt to install it only to get this message "Setup did not find a driver compatible with your current hardware or operating system." I looked this up and found that you must completely uninstall the old version before updating, so I did that and tried again only to get the same message. I tried the other way suggested too, by using the drivecleaner / drivesweeper to remove all traces of it and tried again. Still no luck. What am I doing wrong?
Also, now I do not have the installation CD for the weekend and have been unsuccessful in trying to reinstalled the 8.8 drives. So there must be something the installation CD was doing the the .exe's for 8.8 and 8.9 are not. Please help install either of the two drivers!
