8.10 Beta Catalyst Drivers
Running 8.10 beta hassle free
Warhead DX10 Enthusiast works like a charm at 1920x1200... eventho fps are slightly lower than DX9 it feels alot smoother
I ran identical benchmarks with 8.9 and then 8.10 beta and here are the results:
8.9:
Code:
Processor: Intel(R) Core(TM)2 Duo CPU     E6750  @ 2.66GHz @ 3202 Mhz
CPU ID: Intel64 Family 6 Model 15 Stepping 11
Operating System: Microsoft® Windows Vista™ Ultimate  64-bit Service Pack 1
Physical memory: 4.00 GB
Display adapter: ATI Radeon HD 4800 Series 512 MB
Driver version: Catalyst 8.9 (8.53-080820a-068906C-ATI)
TimeDemo Play Started , (Total Frames: 1882, Recorded Time: 56.90s)
!TimeDemo Run 0 Finished.
    Play Time: 73.04s, Average FPS: 25.77
    Min FPS: 20.44 at frame 878, Max FPS: 34.98 at frame 1775
    Average Tri/Sec: -1479370, Tri/Frame: -57411
    Recorded/Played Tris ratio: 3.26
!TimeDemo Run 1 Finished.
    Play Time: 64.26s, Average FPS: 29.29
    Min FPS: 19.95 at frame 1622, Max FPS: 36.00 at frame 1507
    Average Tri/Sec: -1361614, Tri/Frame: -46489
    Recorded/Played Tris ratio: 4.02
!TimeDemo Run 2 Finished.
    Play Time: 64.91s, Average FPS: 28.99
    Min FPS: 19.47 at frame 1607, Max FPS: 36.40 at frame 741
    Average Tri/Sec: -1085804, Tri/Frame: -37448
    Recorded/Played Tris ratio: 4.99
TimeDemo Play Ended, (3 Runs Performed)
    Play Time: 81.43s, Average FPS: 23.11
    Min FPS: 18.61 at frame 1348, Max FPS: 27.95 at frame 1780
    Average Tri/Sec: -895227, Tri/Frame: -38733
    Recorded/Played Tris ratio: 4.82
    Play Time: 76.17s, Average FPS: 24.71
    Min FPS: 18.42 at frame 1647, Max FPS: 28.70 at frame 1525
    Average Tri/Sec: -849189, Tri/Frame: -34370
    Recorded/Played Tris ratio: 5.44
    Play Time: 74.23s, Average FPS: 25.35
    Min FPS: 18.30 at frame 1351, Max FPS: 29.81 at frame 1542
    Average Tri/Sec: -1291390, Tri/Frame: -50936
    Recorded/Played Tris ratio: 3.67
    Play Time: 90.27s, Average FPS: 20.85
    Min FPS: 16.67 at frame 1630, Max FPS: 26.06 at frame 1463
    Average Tri/Sec: -1064710, Tri/Frame: -51070
    Recorded/Played Tris ratio: 3.66
    Play Time: 79.51s, Average FPS: 23.67
    Min FPS: 16.67 at frame 1630, Max FPS: 28.17 at frame 1777
    Average Tri/Sec: -958658, Tri/Frame: -40500
    Recorded/Played Tris ratio: 4.61
    Play Time: 73.09s, Average FPS: 25.75
    Min FPS: 16.67 at frame 1630, Max FPS: 30.47 at frame 1484
    Average Tri/Sec: -1117047, Tri/Frame: -43382
    Recorded/Played Tris ratio: 4.31
    Play Time: 121.61s, Average FPS: 15.48
    Min FPS: 10.94 at frame 1633, Max FPS: 18.64 at frame 1538
    Average Tri/Sec: -818427, Tri/Frame: -52885
    Recorded/Played Tris ratio: 3.53
    Play Time: 114.78s, Average FPS: 16.40
    Min FPS: 10.94 at frame 1633, Max FPS: 18.99 at frame 1490
    Average Tri/Sec: -452882, Tri/Frame: -27620
    Recorded/Played Tris ratio: 6.77
    Play Time: 112.44s, Average FPS: 16.74
    Min FPS: 10.94 at frame 1633, Max FPS: 19.60 at frame 1496
    Average Tri/Sec: -546686, Tri/Frame: -32663
    Recorded/Played Tris ratio: 5.72
//////////// Summary \\\\\\\\\\\\\
10/01/2008 22:28:15 - Microsoft® Windows Vista™ Ultimate  64-bit Service Pack 1
DirectX 10 ENTHUSIAST 3X @ Map: frost @ 0 848 x 480 AA 0xx
==> Framerate [ Min: 19.71 Max: 36.20 Avg: 29.14 ]
DirectX 10 ENTHUSIAST 3X @ Map: frost @ 0 1280 x 720 AA 0xx
==> Framerate [ Min: 18.36 Max: 29.26 Avg: 25.03 ]
DirectX 10 ENTHUSIAST 3X @ Map: frost @ 0 1360 x 765 AA 0xx
==> Framerate [ Min: 16.67 Max: 29.32 Avg: 24.71 ]
DirectX 10 ENTHUSIAST 3X @ Map: frost @ 0 1920 x 1080 AA 0xx
==> Framerate [ Min: 10.94 Max: 19.30 Avg: 16.57 ]
8.10:
Code:
Driver version: 7.01.01.830 (20080911090934.250701-000)
    Play Time: 70.63s, Average FPS: 26.65
    Min FPS: 18.35 at frame 882, Max FPS: 33.14 at frame 714
    Average Tri/Sec: -1300276, Tri/Frame: -48795
    Recorded/Played Tris ratio: 3.83
    Play Time: 63.51s, Average FPS: 29.63
    Min FPS: 18.35 at frame 882, Max FPS: 38.14 at frame 1804
    Average Tri/Sec: -490858, Tri/Frame: -16565
    Recorded/Played Tris ratio: 11.28
    Play Time: 61.01s, Average FPS: 30.85
    Average Tri/Sec: -888898, Tri/Frame: -28817
    Recorded/Played Tris ratio: 6.49
    Play Time: 86.54s, Average FPS: 21.75
    Min FPS: 17.14 at frame 495, Max FPS: 27.83 at frame 1503
    Average Tri/Sec: -1292857, Tri/Frame: -59447
    Recorded/Played Tris ratio: 3.14
    Play Time: 80.16s, Average FPS: 23.48
    Min FPS: 17.14 at frame 495, Max FPS: 27.96 at frame 1547
    Average Tri/Sec: -576923, Tri/Frame: -24574
    Recorded/Played Tris ratio: 7.60
    Play Time: 79.84s, Average FPS: 23.57
    Min FPS: 17.14 at frame 495, Max FPS: 28.40 at frame 1505
    Average Tri/Sec: -888146, Tri/Frame: -37675
    Recorded/Played Tris ratio: 4.96
    Play Time: 91.21s, Average FPS: 20.63
    Min FPS: 16.20 at frame 392, Max FPS: 25.61 at frame 1457
    Average Tri/Sec: -666565, Tri/Frame: -32304
    Recorded/Played Tris ratio: 5.78
    Play Time: 82.51s, Average FPS: 22.81
    Min FPS: 16.20 at frame 392, Max FPS: 26.40 at frame 1558
    Average Tri/Sec: -1012253, Tri/Frame: -44379
    Recorded/Played Tris ratio: 4.21
    Play Time: 81.50s, Average FPS: 23.09
    Average Tri/Sec: -981272, Tri/Frame: -42492
    Recorded/Played Tris ratio: 4.40
    Play Time: 123.48s, Average FPS: 15.24
    Min FPS: 12.06 at frame 1623, Max FPS: 17.50 at frame 1527
    Average Tri/Sec: -782631, Tri/Frame: -51350
    Recorded/Played Tris ratio: 3.64
    Play Time: 115.95s, Average FPS: 16.23
    Min FPS: 11.75 at frame 1659, Max FPS: 19.28 at frame 1533
    Average Tri/Sec: -583389, Tri/Frame: -35941
    Recorded/Played Tris ratio: 5.20
    Play Time: 112.62s, Average FPS: 16.71
    Average Tri/Sec: -777660, Tri/Frame: -46536
10/02/2008 22:21:57 - Microsoft® Windows Vista™ Ultimate  64-bit Service Pack 1
==> Framerate [ Min: 18.35 Max: 38.14 Avg: 30.24 ]
==> Framerate [ Min: 17.14 Max: 28.18 Avg: 23.53 ]
==> Framerate [ Min: 16.20 Max: 26.40 Avg: 22.95 ]
==> Framerate [ Min: 11.75 Max: 19.28 Avg: 16.47 ]
Bottom line was at least in my tests 8.9 was faster. But this may not have been the greatest benchmark to use as there is a lot of action and the AI isn't consistent with each run-through.
Ok, where do I get the Warhead benchmark tool?
I just installed my Diamond Oc'd 4870x2 and played Warhead. The screen locked up a few times and finally the computer rebooted.
RATS!
Tried that custom config. Runs great when it runs...but I'm getting a lot more crashes on checkpoint loads. Although, I was getting them before this anyway.
