7970 temps
GPU WZRD
What are the temps of a 7970 GHZ edition X-vapor at stock and then O/C'd at various speed? thanks =)
That depend a lot on your case, room temp.... It could be in the order of 65-75 Celsius in a typical airflow case and room temp...
Yeah, a lot depends on your case airflow. For example, I have a H100 with a push/pull setup (a air filter between to keep dust out) 2 120 fans blowing straight down into the case with a 120 exhaust fan and 2 120 side fans aimed directly at my 2 reference cards.
I hit between 61 - 65c degrees max
