hoping not to start a flame ware but realize it will probably happen.
i have a 7970 that oc's very well. 1220/1775 (maybe better on 920 water cooling).
just bought a 680 oc windforce that does 1265/1700.
i game at 5760x1080 and loathe multi gpu setups.
need to keep one.
680 positives:
MUCH quieter. no 3 screen tearing. surround is slightly more polished than eyefinity. oc's well. can play witcher 2 in surround, currently doens't work in eyefinity.
negatives: pours heat into the case, mobo gets much warmer than before. not quite as fast, although is not a big hit on actual gameplay. oddly enough seems to have more cpu utilization (79% max vs. 65% max on the 7970)
i could sell the 680 and buy a antec kuhler and mount to watercool the 7970, thus putting up with tearing and less polish in exchange for raw frames. but would also lose out on witcher 2 3 screen goodness.
what would you guys do? i figure net dollars would be fairly equal keeping one or the other.
thanks for advice guys.
need to keep one.
680 positives:
