- Apr 4, 2012
So I've got the itch to do some tinkering...
My current system includes a 2600k on an H80, at 4.4ghz and a Diamond 7970 reference board which is running at factory clocks.
When I first got the 7970 I oc'ed a bit just to see what it would do, and at factory voltage it will run 1125/1500 stable under unigine heaven and furmark... with the fan set to 70%. (OMG Loud)
I've wanted to invest in the stuff needed to run a full loop for quite some time, and so I find myself looking at spending $600 for a D5/CPUblock/GPUblock/2x360mm rad setup just for fun. On the other hand, I could sell the current setup and end up with a I7 4770k and R9 290 combining the proceeds with the $600.
In a year or two when I'm yearning for extra performance from the 4770/290, I'll again be imagining a full W/C loop...
So... what say the Hard members?
1- Buy the latest stuff and forget fancy watercooling.
2- Get some type of hybrid/aftermarket GPU cooler to O/C the 7970 and save my money.
3- Go nuts with a full loop and worry about CPU/GPU/MOBOs in a year or two.
