suiken_2mieu
- Apr 7, 2010
So I bought a MSI 7970 Lightning and it has 2-8 Pin Connectors. I have an Ultra 750 Watt power supply that is a little older, but I never had issues running my system with it until now.
It only has 1 8-Pin connector and 2 6-Pin connectors. I used a 6-pin to 8-pin adapter that came with the card. I can get the card to load windows, but as soon as I load 3D content, I lose Video Signal. I don't get it back until I power cycle the system. Oddly enough, If I use 2 6-pin to 8-pin adapters, I can get the card to render 3D for few seconds until I lose video signal.
I put the card into my roommates system, he has a Rosewill 700 watt PSU with the same deal, only 1 8-Pin and 2 6-Pin connectors. I use the adapter in his system and it works perfectly.
So, I'm pretty sure it's not the card. What's weird is that I'm running my 5870 at 950/1200 @ 1200mV, and the 7970 at it's own factory overclock. I tried underclocking it to stock 7970 settings, but as soon as I hit apply, it looses Video Signal.
Do you think my PSU is just not up to snuff? Again, I'm still using it to power my rig and still playing games on my 5870.
Also, I want to go Xfire, so what PSU would you recommended?
Roommates Rig:
i7-950 Stock
AMD 6870 1GB
ASUS Rampage III "Gene" Mother Board
Rosewill 700 Watt PSU
WD 500GB Sata HDD
Random Optical Drive
12GB DD3 RAM
My rig is in my signature.
My 5870
My 7970 Lightning
Roommates Rig:
i7-950 Stock
AMD 6870 1GB
WD 500GB Sata HDD
12GB DD3 RAM
My 5870
My 7970 Lightning
