I just set up crossfire last night with two xfx 7970's (FX-797A-TNFC and FX-797A-TNBC). Catalyst control center says that crossfire is enabled but it isn't getting any kind of information from the second card. No temps, fan speeds, clock speeds, nothing. I tried using hwmonitor, aida64 and speedfan and none of them are getting any kind of information either. Hwmonitor doesn't list any info for the second card, aida see's the card and gets information for a second or two before it zeros out, speedfan seems to think it can change the fan speed but it didn't actually do anything. My temps are all fine I think, the top card (FX-797A-TNFC, the core edition card) is idling at 39C. I guess I should mention that both cards do show up in device manager.
Is it normal to not get any kind of reporting from the second card? I know it's a stupid question, sorry. It seems to me that you would get sensor info from both cards under normal circumstances.
I'm assuming this is abnormal, so, any ideas for fixes? I did reinstall the newest catalyst driver but it didn't help. Should I user driver sweeper to completely remove and then reinstall the drivers?
I don't believe I have any hardware compatability issues but for clarity, this is what I'm running:
i7-950, not overclocked
gigabyte x58a-ud3r rev 2.0
xfx black edition 850w psu
Again, the cards are XFX reference style cards:
pci-e 16x slot 1 - Core edition 7970, FX-797A-TNFC
pci-e 16x slot 2 - Black edition 7970, FX-797A-TNBC
Windows 7 ultimate x64
12 gigs of ram
The cards are running the same bios versions. The difference should just be the clock speeds and in crossfire the faster card should change itself to match the clock of the slower card.
Any help would be phenomenal.
12 gigs of ram
