....Here's my list of models...............
Gigabyte: GV-R928XOC-3GD:
https://www.dropbox.com/s/51d87ch0ps1ja9f/GV-R928XOC-3GD_F60_AGR_ORG.zip
GPU Memory Ratio Hash Rate
870 1500 0.5800 565
885 1525 0.5803 585
900 1550 0.5806 600
915 1575 0.5810 610
930 1600 0.5813 623
945 1625 0.5815 633
957 1650 0.5800 641
972 1675 0.5803 653
986 1700 0.5800 664
1000 1725 0.5797 676
1015 1750 0.5800 685
1030 1775 0.5803 695
1044 1800 0.5800 705
1059 1825 0.5803 707
1073 1850 0.5800 712
1075 1850 0.5811 718
You may have the same card as me what is the model number?I had to perform lots of testing on my 7970 to find the optimal core to memory ratio. I found that to be ~0.58. Here's some of my test data (hash rate was from mining LTC, so scrypt):
Code:GPU Memory Ratio Hash Rate 870 1500 0.5800 565 885 1525 0.5803 585 900 1550 0.5806 600 915 1575 0.5810 610 930 1600 0.5813 623 945 1625 0.5815 633 957 1650 0.5800 641 972 1675 0.5803 653 986 1700 0.5800 664 1000 1725 0.5797 676 1015 1750 0.5800 685 1030 1775 0.5803 695 1044 1800 0.5800 705 1059 1825 0.5803 707 1073 1850 0.5800 712 1075 1850 0.5811 718
Once I deviate from my optimal ratio my hash rate plummets very quickly (eventually down to ~500). I did set powertune to +20% (may not even be necessary, but I didn't spend any time testing if it's stable without it), but I didn't mess with voltages, RAM timings, BIOS flashing, etc. Anyways, I hope this is somewhat helpful as I was quite frustrated with my sub-par 7970 hash rates until I did some digging and then testing and found how critical the ratio is.
Looks like you can benifit from The Stilt's modded bios files also.
if you have the Hynix MFR ram then you sure can as the factory bios has the memory timings all screwed up.
I spent all day yesterday messing with numbers right now at 975/1745 for 668KHS any other changes and I'm going black or gray with black lines
I'll try some of your numbers though
HA Going with your highest setting I get a red screen with black lines. Starting out closest to where I left off with 1015/1750 I'm @ 558khs
Funny how our cards are acting completely different.
drudenhaus ~ # ./amdmeminfo
AMDMemInfo by Zuikkis <zuikkis@gmail.com>
Found card: 1002:6798 (AMD Radeon HD7970 / R9 280x)
Subvendor: 0x1002
Subdevice: 0xb00
Memory type: SK Hynix H5GQ2H24MFR
WTF That is the same exact card! I dunno how we don't do the same hash and why I can't hash at the high ram you do. It overclocks like a dream for benchmarking but shit WTF!
Hehe how about this what is your temp?
hehe 40C here got you up on that at least. What is your Asic quality? Open GPU-Z right click the title bar and select Read Asic quality are you on stock bios?
Stock BIOS. I'd have to reboot into Windows to run GPU-Z though, unless they have a linux version now (and I'm not at home at the moment).
no biggie but that will probably be what sets our cards apart
mine is 75.1%
just tried the tahiti le bios and set the clocks the same and I get 2KHS less and use more electricity with the higher core voltage pretty lame lol
Aren't you guys concerned about voiding your warranty by modding your GPU bios? With these cards being worth $500+ now even used, plus the extreme constant stress mining puts on them I can't justify the risk.
You can always flash a stock bios back. The factory bios with MFR chips are all jacked up and all a modded bios does is correct those memory timings.
The only thing that can really hurt a gpu is extreme temps from over volting. Not to mention in less then a year you can make enough profit to purchase a new card and still have coin to spare.![]()
If the card is toast, how are you going to flash the stock bios back? And the gains in KHash from stock to tweaked BIOS are substantial but would still take many months to cover the cost of a bricked card that you cannot RMA...
