7950gt max 595 core - should i vmod ?
kokke
Hi guys
I have a 7950gt at stock speeds for now (550/700). I've mounted a Zalman VF900 on it, but no sinks on ram yet - I'll do this as soon as the easter holidays are over and the shops are open (I'm from Denmark btw).
My problem is, at anything above 590 on core, I get artifacts and heavy delays. The ram will go to 800 and above, even without heatsinks, but as far as my benchmarks say, It's the core slowing me down. So I'm thinking maybe bumping the voltage.
I have a Zalman VF900 on it, so temps at full load are in the low 50s (centigrade). I just want to know if it's the right course of action.
I've never voldmodded a vga card before, so I have absolutely no idea if this is the right thing to do, but I've overclocked dozens of CPUs, so my experience tells me that if temps are low and I can't get higher, I need to bump the voltage.
So here is the question: Would a voltmod help me get past that 590 wall or have I hit the 7950s max potential?
I've read alot of threads about how to vmod the 7900 series and which ICs to cool etc., so I'm ready to go - I just don't know if it is what I need to get past those pesky 590 mhz.
For reference my system is:
E4400 @ 3,0 ghz watercooled
2x1 gb kingston something @ 900 mhz with loose timing
Gigabyte GA-965P-ds3 v3.3
Antec PSU, 430w and max 20A on 12v
why bother with .5 fps improvement for risking damaging the card? I would guess the card is somewhat important to you since you havent upgraded to a more modern one.
I got the card for free and I have a replacement card collecting dust. I don't care much for the card, I'd just like to see what I can do with it :)
As you can see, the rest of my setup are overclocked budget parts as well. I'd like to see how much of a difference a voltmod can make, as I haven't tried it before on VGA cards.
Go for it, youve got the cooling, i did the pencil mod up to 1.5v and it brought my core up to around 700 if i remember correctly...reversible too if it doesnt work out...just go slow and make sure you check everything twice :) good luck!
Thanks alot :) What do you have the ram set for? Cause I can't see any real difference even in 3dmark when i bump the ram from 700 to 850
EDIT:
Also, how big a performance boost did it yield you? Can you remember?
TBH i cant remember what kinda of numbers it brought, but your numbers on the ram are probably being held back by the slow core...i always run things on the edge
