Huskernation
- Jan 11, 2011
Just got my sapphire 7950 oc version and am using afterburner for the oc. The max on afterburner is 1100 core and 1575 mem, how do I go past this?
start AB with the /xcl switch (eXpand Clock Limits)
it needs to be outside the quotes
it also extends the limits for ccc as well
it basically creates a "soft vga bios" in the registry with new powerplay parameters
if u have issues, drop to a command prompt with admin privileges and go to the ab directory. type "msiafterburner /xcl"
