Hey all. Before I begin, I'd like to say that I have very little experience with OC.
My system that I assembled recently:
Gigabyte GA-Z77X-UD5H
Antec M HCG-620 W PSU
i5 3570k stock
CM 212 EVO for cooling
Gigabyte 7950 windforce factory OC to 900mhz
Windows 7 64 bit
My driver has been crashing nonstop. It's not a hard crash, I can always alt tab out or it recovers to desktop. I get slight artifacts in WoW, like quick flickers or stretchy shadows for a split second. I also got a few flashing models during the Unigen test.
I was playing Sleeping dogs today, a game that I'm not exactly pleased with, given the inconsistent performance on my PC. The game has frequent slowdowns that really take me out of the action.
My regular temps for the 7950 are 55-57C under full load. This was at the factory OC setting. I tried to change drivers around, going from 12.11 betas and 12.10. None of it worked so I used AMD overdrive to return the clocks to stock levels. This seemed to fix it as I got past a part in Sleeping dogs that consistently crashed the driver. Disabling AMD overdrive didn't stop the crashes.
I was also getting these crashes in the Witcher 2, as well as black ops 2, I just wasn't aware and though they were game bugs.
Can anyone with experience point out the problem here? I was going to flash my BIOS, I have a formatted USB drive for Q-flash but I'm waiting to pull the trigger. Is my video card defective? I'm no expert but I would guess it is just getting incorrect voltage. AMD overdrive's voltage option is garbage and means nothing to me so I would like some advice on how to properly overclock the card. I wouldn't expect a factory overclocked card to have these problems with a motherboard from the same manufacturer, but here I am.
Any help is appreciated.
Edit: Forgot to add
Mobo rev. is F8 and the voltage to the CPU and card are set to auto I believe.
i5 3570k stock
Windows 7 64 bit
Edit: Forgot to add
