790i or going for i7?
MorgothPl
Here's the problem. My P5e3 Deluxe is having some bad issues with capacitors - they don't get enough juice to power the machine at first boot, so need to try it few times, before machine starts. The warranty is off, so no chance to RMA it.
Now, here goes the question. Is it worth to go for i7? Becasue I would need the mobo and new cpu (right now I'm on 8400). Because the other option would be to go 790i, either Evga SLI Ultra, or Asus Striker II), because I want to SLI my 280gtx.
What I'm afraid of with new system is that it ain't that futureproof. I still remember 975x going to be high end chipset, and then very soon replaced by x38/x48 so it might have the lifespan as 790i
well my argument against the i7 platform was the cost vs performance ratio (everything but the cpu is sky high). but if your looking at spending the money on DDR3 and a 790i board I don't see the point in not going with intel. for the extra hundred dollars (plus the new cpu) your going to be several steps ahead of the 790i not to mention that the nvidia boards are not know for being all that. Sell off your e8400 and recoup some of the expense
Well the 790i boards are about the same price as the mid level x58 boards (300 range) CPU will be around 350.
Well, I already got 2x2gb Reaper 1333mhz DDR3, for my x38 board, so it's the question of board and cpu. And with Polish price, the mobo + cpu will be about 800 USD, comparing to just 300 for USD per 790i, so it's the 500usd for my 2nd gfx card :)
need one more stick there for the i7. but you have a point, going with a 790i would be cheaper in that you can use your current cpu
The unfortunate rule of the computer business is, nothing is future proof, they said that about the P1's, P2's, P3's, P4's, Dual Cores, Quad Cores, the AMD Athlon's, the AMD 64's....and so on and so on, but they lied like they always do.
Cost wise the i7 920 is not much more than the Q9550 ($15 difference), and the board prices I have seen at Tank Guys is about the same as what you would expect from the current top of the line Dual, Quad, and Extreme mainboards.
I'm holding out for the i7's (that and I'm waiting for a financial boost to arrive in the next few weeks hopefully).
If gaming is your primary use, I'd save some cash just get the 790i and call it a day. 99% of games don't use more than 2 cores, and the ones that do don't utilize them efficiently, save SupCom in AI limited situations.
