790GX (Asus M3A78-T) chipset waterblock?
undertheradar
Anyone here ( I posted in the watercooling forum, but no response...) know what chipset cooler (I would rather water, but if not... I'll make due) I could use to watercool the 790GX mobo?
nonlnear
I'm running a mcw30 swiftech chipset block on mine,it was tight but seems to work ,
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010110575 50001437&name=Swiftech Inc.
My rough measurements put the pin distance about 1-1.5 mm wider than the widest the MCW30 is specced for. Probably doable. I haven't ordered an MCW30 yet (seriously thinking about it), but if I did, I'd probably use some thick rubber washers on both sides of the motherboard when mounting it. Then again, I haven't actually put a block on the board yet. It might not be that big of a deal.
