7900GTX/1900XT/XTX and nvidia based MBs warning
Zappa
Well, thanks to the new 7900GTX's dual slot cooler, I had to convert it to water cooling quicker than I wanted.
I had planned on waiting a few weeks or so before converting the video card to water cooling also but, because of the dual slot cooler, it would not fit on my ASUS SLI MB. My NB fan had died and I had replaced it with a much beefier heatsink/fan. Well, it was too thick. The nubs of the heatpipes wanted to jam into the fan, which also stopped it from seating all the way into the slot.
So if you have aftermarket cooling on those NBs, you will need to either convert it back to an ultra thin solution, or change your heatsink of the video card.
I started looking and noticed all the nvidia based MBs put the NB right against or very close to the #1 PCI-E slot. This also effects ATI 1900XT/XTX cards as they are also long and have dual slot coolers.
So, I ended up having to delay the installation of the 7900GTX until I could get it converted to water cooling.
If you have a thick aftermarket cooler on that NB and plan on getting a card that is dual slot, think of this ahead of time to save yourself some grief.
Yes, the Koolance video card cooler works with the 7900GT/GTX as they have the same exact layout as the 7800, even though they haven't got around to labeling it as compatible.
Why haven't I seen this around before?
Do you have pics? I have the 32 bit flavor of your mobo (A8N32-SLI Deluxe) and you now have me concerned...
I can tell you with certainty that a X1900 XT|XTX will work|fit on an ASUS A8N Premium SLi and on an EPoX 9NPA+ Ultra. That's unmodified retail configuration. I've used one on both motherboards. I've heard no complaints from users of DFI Ultra-D boards either.
I don't have the pics with me at work, but I just installed a NB waterblock on my DFI Lanparty NF4 SLI-DR Expert board, and I still have plenty of room for 2 cards. They would have to be watercooled also unless they were GT's because the GT has a small heatsink. However if you are cooling your NB with water, chances are you are cooling everything else with it as well. I am basically stressing that DFI did an fantastic job fixing the problems I've read so many Asus people complain about, although I think its only on the Expert board so its not like DFI doesn't have problems too.
This is why it didn't work. If you have the stock cooling then there isnt ne problem.
If you are going to water cool, the stock chipset cooling will be working just fine as there is significantly less heat coming off the card (The ambient air from the card is cooler since it is now being transfered to the water rather than the air). Since the heat from the card is now mostly being converted into the water, the air will be cooler, making your stock chipset cooler more effective than it was prior to watercooling your card.
I can tell you with my video card watercooled my chipset ran around 50C or so. With the chipset now also watercooled, it runs at 30C max. 50C is probably fine but I figured for 30 bux why not watercool it too :)
No, I could not get a picture of it without tearing my whole system apart to show it. I would need to have the MB out of the case so I could get a sideways look at card and NB fan with the tube hitting it.
If anyone here has a 7900GTX and Nvidia based MB with the NB right next to the PCI-E slot out of the case and could put the card in and take a pic, that would be great.
Yes, I am sorry if it wasn't clear. The STOCK ultrathin fan/heatsinks will work fine, as the cards seem to be designed for this. IF however, you have had to replace it because it died like mine and you replaced it with an aftermarket one that is even 1/4" thicker, then you will have issues. Mine was just a small one with a fan but it was like 1/4" thicker than the stock one and that was too thick.
Either way, I now have the Koolance video card cooler on it and no issues.
If you don't run water cooling though and you have anything but the stock NB heatsink on there, be ready for some issues, unless the one you have on there is really thin.
Of course, this only goes for the dual slot coolers.
NOTE: I haven't physically tested the 1900XT/XTX cards but was looking at them and they appeared to share the same issue, that's why I included them in my warning, that you just need to look into this and be prepared to deal with it. The 7900GTX I know for a fact though.
Seems kinda high...
My Ultra D idled at 30 on the stock cooler, even with my modified air cooling (prior to WC) on my GTX... Never reached 40 on load... Might be the airflow throughout your entire case.
BLiTzKRiEG said:
Seems kinda high...
The thermosensor is located off chip anyway, so it's usefulness (especially when comparing between different systems) is limited.
