7900GT Temps
Boyo
Can someone tell me what temps a 7900GT should be running at? I ask because I'm not sure if I am running too hot. In the nVidia control panel I am getting readings of 52C at idle.
This is the stock heatsink right? If so I idled at 50 on the stock heatsink so it isnt that bad.
Yes, I'm just using eVGA's stock heatsink. I wasn't sure if 52C at idle was normal and if i should look into an aftermarket HS.
