7900GT Problems
Sacrifice
Hey,
I seem to be having constant problem with my eVGA 7900GT: http://www.newegg.com/Product/Product.asp?Item=N82E16814130033 . It always seems to go into this locked up state, and the screen appears to be a bunch of little triangular looking figures when i'm gaming. Mainly when I'm walking into smoke or there are sparks in the game. I can still move around and shoot etc., but the screen will stay in the messed up state and need a reboot. It still does it after an RMA from eVGA. Now, I'm thinking maybe it's the PSU: http://www.newegg.com/Product/Product.asp?Item=N82E16817153032 . They recommend 20A on the 12v Rail, and I realized this one only has 19A, correct? Or should this PSU be more than enough to handle that card? Has anyone else had this problem...I'm seriously considering going to Radeon, I threw a X850XT in there from an older computer and NO problems at all. Drivers are all up to date. Even tried messing with resolutions/refresh rate/vsync on and off. Any suggestions? Thanks!!
Not a problem with the psu, it has 19x2 = 38 Amps total for 12v.
Are you getting the exact same problem before and after the RMA?
Yea, before and after RMA. I flashed newer bios yesterday to the newer version and it wouldn't boot, so I rolled back one version. Still newer than the bios I had. So wel see if that works, and then if it doesn't I'll try different graphics drivers. Just trying to find someone who had the same problem and fixed it, it's very annoying.
