7900gt or 7900gtx
crazymonkee84
At the moment i want to step my 7800gt up to either a 7900gt or 7900gtx. I have a 19" LCD monitor with highest res of 1280x1024, an athlon 64 3200+ venice oced to 2.5, an epox 9npa Ultra motherboard, 1 gig or kingston ram, and a 250gig maxtor hardrive. Should I just upgrade to the 7900gt or should I go to the 7900gtx. Im using the Evga step-up program so id be paying about 40 for the 7900gt and about 200 for the gtx. Does anybody have any suggestions as to what I should get?Thanks in advance
Any chance you will upgrade your monitor within the next year? Also what games are you planning on buying in the next few months? ;) Suggestion to follow after these questions are addressed
no I wont be upgrading my monitor and Im not completely sure at the moment im like a call of duty 2, battlefield 2, css etc player. In other words a FPS person. Im not relaly into like the Sims or Civilization games you know. O ya and my choices are between 7900gt CO 7900gt CO superclocked, or the 7900gtx egs. And DX10 i doubt ill be gettn the first cards that come out for it.
7900GT. At your current resolution it's perfect. The 7900GTX 512mb is overkill based on the resolution and games you are playing. Save some $$$ and get some of those games you want and enjoy that 7900GT CO ;)
so just stick with the 7900gt co not co superclock? its like 30 dollars more but +50 on core +80 on memory clock and the memory bandwith is a bit higher. Is that worth the extra money? O and i wont be overclocking at all heh i value the lifetime warranty waaaaaaaaaaaaaaaaaaaaaaaaay to much heh
Get the regular and overclock to make up the difference. If you can reach that (superclocked) speed on your card by overclocking then go here www.mvktech.net and download/flash the bios to the CO superclocked version on your card and enjoy the $30 you saved.
Thanks, I enjoy it alot. I put it to alot of use and especially will with ES4 Oblivion, Prey, Enemy Territory Quake Wars, Unreal 2007 which are all on my radar.
someone told me to splurge for the 7900gt CO superclock just cuz i wont be overclocking and its just a bit more what you think about that?
If you flash the bios you wont be overclocking. They are the same card essentially. One is just factory overcloked with higher frequencies. The other will require a little leg work on your part. It's your call.
well ive never relaly flashed a video card before...cept my 9500pro/9700 which the guy i bought it frm flashed it wrong so i had to flash but that doesnt really count. I dont know maybe i could get a friend to help well ill just stick with the 7900gt CO lol im trusting u thanks again
Look at my sig. Those cards didn't come at that clock frequency. LOL :D I could have shelled out $650 but thought $499.99 for a regular and then making it a Superclocked was more attractive. Although I'll admit I didn't pay 499.99 or more than that for that matter but let me not go there.
lol lucky lucky u o ya and like changing the bios so that my CO will be a CO superclock would that cause artifacting?And do you think i should get 2 gigs of ram with that remaining money?or go get myself a new cellphone since my razr broke.....
It might. What I always recommend is that you overclock the card and run some benchmarks and check for artifacts. See how high you can overclock the card before it becomes unstable. ATI tool is great in that it has a artifact test. If you can hit the CO Superclock speeds without artifacts in 3dmark & ATI tool Your ready to flash it to the CO Superclock then no need to overclock anymore it will always run at that speed.
I'm in the same position. I decided to step up my 7800 GT to the 7900 GT and I am #266 in the queue. At first I thought about the 7900 GTX but I have never had a $500 card before ($350 is my limit). I run 1280x960 on my 19" monitor and play BF2 and UT2k4. I think the 7900 GT will fit perfectly.
Jeff
