- Jun 6, 2005
Well, I took the HS off of my eVGA 7900GS to replace the thermal compound with some AS5. I had heard that AS5 also works better than the stock thermal pads on the RAM.
So I pulled off the pads and applied AS5 to all the RAM and to the GPU core.
When I replaced the HS, I looked to make sure everything was in order and noticed a very visible gap between the HS and the RAM chips.
The RAM isn't even near touching the HS. Now, I'm scared to plug it back in and use it and the thermal pads aren't in such hot condition now...
What do I do?
What do I do?
