7900GS or X1950PRO?
The 1950s are doing much better with newer games. Miy 7900gs blows in overlord and vegas, and I've seen 1950 pros that play them just fine. Also not every 7900gs will overclock, like anything it's luck. I need to volt mod mine to get the core up past stock, but the memory is stable at 850 stock voltage.
Well, for what it's worth - the 7900GS is more of an "adventure" :)
You find yourself wanting to go further and further with it. I ended up getting a new Zalman VF900 (and the 3600RPM max speed version as well) for only $15 shipped. What turned out as a once "I won't go above 1.3V" is now "I am going to try to hit 700MHz on the core with 1.55V and hope the temps are reasonable". I already tried 1.5V and hit 670MHz (I think mine is very average in overclocking).
I just first need to test 80F+ ambient load temps. The Zalman at 1700RPM (with a PCI exhaust below it) did a very nice job at 1.5V 75F ambient outside of the case loading at 60C during a quick half hour session of STALKER. A rise in 10F can translate into a rise in 10C gpu. But I'm also not even running at 50% fan speed. I also have a PCI exhaust fan below it to help get rid of any warm air that may build up around the heatsink since it does not exhaust air out of the case itself.
I'm actually now very happy with this 7900GS now that my fan speed issue is gone.
700/900 here I come!
Is there a big performance difference between the 256mb and 512mb versions of X1950pro?
I'm thinking I'm going to buy one of these bad boys, as I don't really have the money for a 8800GTS. Right now I only have a 19" Samsung 940B which runs at 1280x1024.
Well I went ahead and went with the X1950PRO 256MB version. Don't yell at me, I wanted the 512 but I was already pushing my budget. Should be here Wednesday/Thursday! :cool:
I think I'm going to snag the Sapphire X1950XT 256mb that is on newegg. $150 after rebate is too good of a deal to pass up.
