7900 GTO coolling..
Copyright
I dont know much about this card but the cooling looks like it would be fairly quiet? What it be worth it to go ahead and remove the stock paste and use artic silver 5 before I install this thing? Thanks for any input.
It is very quiet, though it would benefit from better thermal paste.
Yes. Expect 5 to 10 degrees tempature difference at least. Make sure theirs no thermal pad and if so make sure theirs no gap between your heatsink and vpu.
it's a great stock cooler. Two of them in my P180 case are extremely quiet, especially compared to the X1900XTX they replaced. It's like someone removed a hair dryer from my case.
the p180 is the quietest case around, the XTX is the noisiest cooler around. I've had both, and I'm glad I sold it
Does anyone know if there are thermal pads used on the GTO? I dont want to end up with a gap that will just make it run hotter....
Yes, thermal pads are used on the cooler. I suggest you leave them there.
