7900 GTO -> ati 4830?
THRESHIN
considering the above upgrade soon. the 4830 will be on water and overclocked to the moon of course;) so i'd expect slightly above 4850 performance levels from what ive seen.
how big of an improvement should i expect here? system is an opteron 165 @ 2.8Ghz btw. also on water.
the other more expensive option i am considering is putting two 9800 GT's in SLI on water....but for cost/performance the 4830 seems to be the better deal here. comments? i'd like to crossfire two of the 4830's at some point but i don't think my mobo would play nice there:p asus A8N32-SLI (nforce 4 chipset). unless anyone knows of some sort of hack to enable crossfire, i think i'm screwed there....so - what do u guys think?
Yes, the HD4830 will be ~3-4 times faster than the 7900GTO
HD3850 has nearly twice the performance of the 7900GTO.
And the HD4830 has double the stream processors of the HD3850.
The HD4830 and 9800GT preform about the same, but I'd give the performance edge to the HD4830, they are usually a tad cheaper, and I love using the HDMI audio pass through to my stereo/HDTV setup.
There's no hacks to enable Crossfire on a SLI motherboard that I know of. Plus, seems like a waste of time. I would just pick up a HD4870, GTX260 or HD4850x2 if you want more preformance at double the cost.
7900 GTO...
Good memories of that one... of course, that was too long ago :p
yea well i HAD two but i decided to try voltmodding...killed one and the other one works. but hell it wasn't worth the trouble lol. with how cheap the 4830 is i dont really care though.
