780g -> 790gx = decreased performance?
fhetw
Not sure if this is the right place but here goes:
So Im building an HTPC/work pc for a relative so I decided to just throw my M3A78Pro into that and get an M3A78T for myself. The only thing I changed was the mobo, and I ended up reformatting the windows partition. However, now it seems to be taking a little longer to do everything, such a boot/load programs, load games, etc... And the PCMark05 (only diff is onboard video) decreased from 6400 to 5600. Anyone have any ideas on this noticeable performance decrease?
[edit]tried out source engine just to see, and im getting ~10-15 lower fps and ~5º hotter :(
Um, drivers properly installed?
SATA or IDE drives? You should probably list your complete set up to be thorough.
amd 940 @ 3.0ghz
Asus M3A78-T upgraded from Pro
4gb Gskill ddr2-800 1.8v
1TB Hitachi 7k1000.B via sata
LG DVD-RW via sata
Corsair 650tx
I used the packaged driver cd for each respective mb with each install of Windows XP
prefetch takes alittle while to become optimized, did you install sp3, AMD driver installed ?.
You've been here how long and you use the drivers that came on the cd!?
Go to amd.com and download some new drivers
in his defense amd.com doesnt have chipset drivers for the 790gx. im trying to download new ones so when my board comes in, and i cant find any. ASUS website has some but the download is messed up
Also in the OP's defense, the IGP drivers are not the most obvious to find since HD3300 wasn't always listed as downloadable as it is now. When I checked early last month I recall only seeing the HD3200 :p.
But really, the catalyst graphics drivers, which are included in the igp package, support radeons all the way back to the 9xxx series. But everybody has to learn I guess.
