7800GTX seeing a weird speed ...
rajs
Have a eVGA 7800GTX Factory OC at 450 / 1200. Drivers are Forceware 77.77 and have RivaTuner 15.6 installed.
I've set my 3D Performance settings to 490 GPU / 1275 RAM. I ran the Hardware monitoring item within RivaTuner and noticed the following behavior.
Standard nothing running really except normal Windows apps and the RivaTuner Monitoring is showing ~ 275 CPU and ~ 1275 RAM speeds.
I go into BattleField2 and I see the following - The CPU Speed jumps to 529 ... RAM stays at ~ 1275. When I exit the game the graph in the RivaTuner Hardware monitoring shows the CPU goes from 529 ... steps down to 450 for a few seconds and then steps fully down to 275. The RAM stays the same speed.
Question -- Why is it jumping up to 529 MHz speed when I've only selected 490 ?
Anyone else seen this ?
BTW -- I've seen this with both WoW and BF2. I am running 1920x1200 res and have confirmed the 490/1275 speed setting in the Forceware Driver also under the display properties, adv settings, 7800GTX Tab, etc area.
Thanks!
The 7800gtx kinda powers down when its not needed. I guess its kinda like amd's " Cool and Quite "
Except on the 7800 it actually works :p
um...Cool and Quiet DOES work...
1) enable it in your BIOS
2) choose Portable/Laptop in control panel>power option>power schemes
