7800gtx Problem
1337xGamer
I recently installed my new watercooling and my comp was working fine. Then once i started playing a game the computer artifacted like mad and then turned off..how when i boot up even the windows artifacts and my dfi sli dr lanparty symbol. I noticed some water on the card but the bottle says its nonconductive...I reseated the block on the gpu and made sure all was well....another thing.... while playing the game i spelled burning right before it turned off and the card was at 35 degrees.....I also tried a dif card in my comp and it worked fine...any ideas?
most non conductive fluids are not really non conductive. your card probably shorted out and somthing died. first take off the H20 block. clean off the spot where the coolent leaked with rubbing alcohol and put the stock HSF back on and see if it works
