repoman0 said:Get an ATI card, an X1900XT is about the same price as 7900GTX (right?) And it spanks it, IMO. I run 1792x1344 with HDR and it gets no lower than 40fps in Oblivion. Not only that, in CS:S I do 1920x1440 6xaa 16xaf +HDR- in office I get no lower than 80, usually ~120 and in militia, most stressful map, I get no lower than 45.
cyks said:Upgrade proc
General Crespin said:If money is no object: sure, why not?![]()
Blue Falcon said:I can't believe that 1280x1024 is now considered a 'low' resolution... sheesh.
Seriously...1280x1024 is considered HD 1080
datamage said:No, it isn't. 1080p = 1920x1080.
Anyhow, I'm in a similar boat,. only I'm thinking of going from a 7800gtx to the x1900xtx.
ElMoIsEviL said:Because that's an upgrade...
7800 --> 7900 is a sidegrade... you get the same thing but it performs a tad better.
x1900XTX is the best card out at the moment. Only an nVidia groupie would disagree with this statement.
It's able to perform on par or faster then a 7900GTX but able to use higher quality features and higher levels of eyecandy.
Only Noise holds the x1900XTX back... most people buy aftermarket coolers but I would love to see ATi hire Thermalright to make there stock coolers.
