NXLTrauma25
- Jan 5, 2007
Hey all
My BFG 7800gtx seems to be unable to go above 500 on the core and 1320 on the memory
although it can do 1350 on memory if core is left at stock speeds
as of now I am using HeavyH20s 473 core bios and I have tried ocing on stock bios and that
System is watercooled and temps are fine
cpu is a 2.7ghz 4800x2
I see 7800gtxs go over 500 and 1350 on air ALL the time
seems as if maybe this is a volt starved card that has nothing left at all or maybe something else is wrong here
I am using the 92.91 beta drivers as I have heard these are the best from multiple people...they also seem to give me a better score then most drivers in 3dmark0-5 at about 8750
any suggestions or ideas would help
also is it a possibily that voltage to the actuall pci bux would yield better results or is this a negative thought
I have alot of experience with ocing so I can do almost anything you suggest
