if i upgrade my 6800gs to a 7800gt will my enermax liberty 400watts be able to power my system...no o/c everything at stock speeds...my comp is on sig...thanks ..is this even a good upgrade or not
Yep, it should run the card fine as long as you have 18+amps on the +12v line, when mine was a single it ran fine with a powmax 480watt with 18amps on the +12v line.
As for it being a good upgrade, it depends what games you play, if they are all titles from 2006 and before, then your probably good to go, Even with SLI 7800GT's its looking like they are quickly being outpaced for 2007 games, example is cellfactor revolutions free game, i have a avg framerate of 15fps, i haven't checked to see if its actually using both cards though. I'd have to say it might be a good deal for 100$ or less, i bought my 2nd one shipped for 105$
I was looking into downloading lost planet demo for the benchmark but looks like a vista only title.
yea 100 is about the price..used from a user from the forums...how do i know if im getting that many amps on teh 12v line?....i dont have the psu right now its being RMa'D ...
how are you getting a 7800gt i thought they are out of production
no sli for me....all i will be using is gear in teh sig..with no overclocking all stock speeds with a 400watt enermax liberty psu.....so the 7800GT good to go?Yours and my rig are very close. I use an overclocked 4200+ X2 with SLi'd XFX 7800GT Extreme Edition cards and games still run at a very respectable frame rate 30+ @ 1680X1050 res with nice levels of AA and AF. This includes Stalker and Supreme Commander.
To the OP. Yes your 400w PSU will be fine, however if you want to go SLi with them, you'd need to upgrade.
