7800GS - AA settings Question
Kahnvex
In my Control Panel settings for Transparency AA I have two choices: Multisampling, and Supersampling.
I'll be running 2xAA up to 4xAA max, depending on the game, which option is best?
Games played will mostly be stuff like BF2, Command and Conquer 3, or older.
Awesome thanks!
One more... if'n you please... =)
Gamma Correct Antialiasing? is there a performance hit on that or no? Or, does it make a difference?
Actually, if you can afford the performance hit, supersampling is better for transparency AA.
Only use multisampling if you just don't have the framerate to spare.
