Fistandantilis
- Nov 22, 2004
7800GTX or the x1900XT?
I am buying tonight, let me know what your thoughts are, thanks
I'm assuming that you're talking about the 256MB 7800GTX.Fistandantilis said:7800GTX or the x1900XT?
with this monitor, the 256 7800gtx should be fine for a couple years? (ill be playing fear, css, bf2...the usual)Fistandantilis said:ahhhh shat, sorry guys I misread something on new egg...I will be getting the 7800GTX. sorry for the confusion
RavenD said:Also take into consideration the monitor you're going to be gaming on. If its an LCD with a native res of 1280x1024, more than a 7800GT would be overkill.
at cyberpower, where im buying, its $11 more than the 256 7800gtx. Should I pull the trigger if Im on a 1024*1024 with css, fear, and bf2?HybridHB said:Have you considered a used X1800? You can snag em in the forums pretty cheap and imo is better than a 256 gtx.
I assume that youre talking about the x1800xt...Budwise said:i would..
NO....jcll2002 said:Someone said that its overkill to get over a 7800gt on a 1280*1024 monitor. Is this true?
jcll2002 said:at cyberpower, where im buying, its $11 more than the 256 7800gtx. Should I pull the trigger if Im on a 1024*1024 with css, fear, and bf2?
The benchies are pretty much exactly the same. Also, Ive had a nvidia and it was great and Im not sure about ati (just bias)
I dont think ill upgrade again (hope not), but i do think that Ill be keeping this rig for a couple of years.Megalomaniac said:a) there is no such thing as overkill. think aboput the future, there will be games that you will want to play 2 years later, which this card will still eb able to handle well.
you might also get a bigger monitor, who knows.
b) there is no point in getting the 1800 right now.
not when the 1900 is that much better, and that close to it in price.
c) the 7800GT is still the best bang for buck.
especially if you plan to upgrade again and dont want to go all out.
Fistandantilis said:http://www.newegg.com/Product/Product.asp?Item=N82E16814131006
you guys think that this will be better than a GTX? let me know so I can cancel the order(I already ordered the GTX)
jcll2002 said:x2 4400+
x1900xt (or 7800gtx still not sure...)
1gb ballistix + 256 corsair value
74 gig raptor a8n-e
ect...
yeah...Slo Gun said:Get 2 gig or ram.
Youll need it, i just recentrly upgraded to the x1900xt and only had 1gb, found that it couldnt cope with fear.
I know have 2 gig of ram, all is well.
Have the same cpu aswell, although it is oc'd
The thing isheatlesssun said:If there is ever a time to wait, then this is it. This year will see perhaps the biggest changes in power and features from the begining of the year to then end for PC's and gamers then any in the five years at least.
What we've got comming....
1) New Intel CPU's, perhaps Intel takes back the enthusiant market?
2) New AMD CPU's, Socket AM2. While a modest upgrade, its still new platform!
3) Windows Vista... probably the change with the biggest impact to gamers is here DX10!
4) DX10 GPU's
So if you can, wait for a little dust to settle, unless you just want the most poweful system you can get at the moment or don't want to wait.
I orderes this card asus EN7800gtx 256 for the new puters that I am building for my twin's. They are very good card's for the buck. I put them in 4 different system's and they have NOT gone down in any way. I do not own or know anyone who owen's the X1900XT but this board does every thing that you ask it to doFistandantilis said:7800GTX or the x1900XT?
jcll2002 said:1) ive seen in many reviews that the x1900xt is extreme overkill for a 1280*1024 (or could someone find me the best, high res monitor for $300)
4) DX10 GPU's
Sir frag, can you answer the concerns i have?jcll2002 said:The thing is
1) I hate intel (lol)
2) wont it take a long time for the mobos and cpus to be bugless for AM2(m2?)
3)wont that^^^ be pretty expensive at the beginning with bugs?
4)Can i just upgrade my os to vista later? (I know ill have to reformat, ect)
5) Can you explain alittle more about the technology of dx10, the prices, and the waiting time?
Thanks,
jcll2002
jcll2002 said:So I shouldnt bother with the x1900xt, its $40 more
Bothered by IQ? lol I have no idea what that means.
BTW, ill be keeping this system for a LONG time, if that matters.
Yeah. Ignore that. Wasnt thinking straight - not taking into account things like 6xAA 16xHQ AFjcll2002 said:I assume that youre talking about the x1800xt...
Also, will later games take advantage of the 512 mb? Is it silly to get a 256 card now?
