7800 Gtx Oc Sli?
Ice6699
First are my PC Specs:
I have two BFG 7800 GTX OC's. My Motherboad is a Foxconn NFPIK8AA-8EKRS. Its a socket 940 Mobo. Got an Opteron 148, 2 x 1 GB of Corsair XMS Dual Channel ECC Ram (freakin expensive), 2 x 250 GB SATA and a 120 GB SATA, a 600W Enermax Noisetaker SLI powersupply.
(BTW nothing has been overclocked other than the videocards which come overclocked by BFG.)
Now, when i plug in one video card, the pc works fine. It boots up, Posts, and loads xp fine.
When i put in two, the pc powers up, but theres no post, no loading, no whatever (even that familiar beep in the beginning is gone). Ive swapped videocards thinkin that one might be defective. But in single videocard mode, they both work fine. Yes i have connected the sli bridge correctly as well. Ive contacted the Motherboard manufacturer and they said that I am doing everything correctly, and they dont know what it is.
I also have the most up to date bios revision on my mobo (since they never released a new bios revision cause they didnt need to :p )
Could it be the bios revisions on the video cards?
Could it be a defective mobo? (BTW my mobo screwed around with me once when the power went out and my powerbar was useless against it. I had to reset the cmos jumper and ive had to do that ever since. Foxconn doesnt know n e thing about that issue either. Seems like everytime i call them its always the same guy picking up.)
Please help meee :(
Tough to say. If they both work by themselves than the issue isn't with the video cards. Your power supply should be enough unless you've got a ton of hard drives in the machine.
I am reluctant to say motherboard, but I am having a hard time calling it something else. I can say with relative confidence that it is not a video card issue.
Try each card independantly in both PCIe x16 slots. It could be the bottom PCIe slot that is causing that problem. Just something else to rule out anyway if you haven't already.
