7800 gt sli... huh?
ampedxc27
i have 7800 gt sli and i was just playing call of duty 2 and it lagged like crazy. i thought this was supposed to do very well in every game out with highest settings. im playing with highest settings for every game at 1280 x 1024. i have a sonata 2 case w/ 450 watt power supply and 3800 x2. all my drivers are up to date. is my power supply not enough? is something else wrong here?
ampedxc27 said:
i have 7800 gt sli and i was just playing call of duty 2 and it lagged like a bitch. i thought this was supposed to rape every game out with highest settings. im playing with highest settings for every game at 1280 x 1024. i have a sonata 2 case w/ 450 watt power supply and 3800 x2. is something wrong here?
first of all how can one "lag like a bitch"
Second of all i did not know 2 video cards can rape a game.... They dont have sexual parts and they arent alive.
you're really useful.
have you tried any other games? i've found that call of duty 2 is just hell on video cards, period. even tuning the settings down and it still chops out SLI or none. quake 4 on the other hand is smooth as butter and a real visual treat.
imo Call of Duty 2 just isn't making very efficient use of GPUs and it "lags like a bitch" on pretty much all setups. Even GTX 512s aren't scoring great frames in it.
ok...i made it more politically correct. i'll try it in counter strike and see how that goes.
ok, cs:s went like this
Militia w/ full hdr: about 20-30 with spikes into the teens.
Office: pretty solid framerate, dipped below 30 mabye once or twice.
Video Stress Test: 35 fps..
those seem very low. my single 7800 gt did better than those. i must have a setting wrong somewhere. and yes, sli is enabled.
That seems a tad low for CS:S, what are your settings? Fresh driver install? Chipset drivers?
sli aa x 8, sli af x 16 i think. gamma aa, some other high end aa stuff. fresh install today, ive got the chipset drivers too. before that it was horrible.
try reinstalling the drivers using driver cleaner 3 and make sure you leave all the settings to default, except the one setting that asks you if you want to use sli. Tell us how it goes.
k man, just leave the driver's settings at default. Change the in-game settings to something like 4xaa, 16Xaf, at 1600x1200 res.
Here's a quick checklist for you. Some of them are really basic things, but they are sometimes overlooked.
1. Did you set your jumpers/bios options to enable SLI (methods vary by mobo model)
2. Did you use the SLI bridge between the cards?
3. Did you enable SLI in your nvidia display properties?
4. Are your cards overclocked? If so, do you still have problems at stock speeds?
5. Are your cards overheating?
1. No, i just put the cards in and put the bridge on. Is there something I should have done. I have the evga sli motherboard.
2. Yes
3. Yes
4. They are factory overclocked, I havn't done any yet.
5. I don't think they are. 50 C idle and about 60-65 load.
Check your evga motherboard manual. Although you may have installed the bridge, there should be either jumpers on the motherboard for you to switch from single to sli mode. Alternatively, in the bios, there is this option.
If SLI was selected by either method then go below:
Go to video properties...see if sli is even enabled...this happened to me once...although this may sound remedial, do this:
1. click video card properties.
2. select settings
3. Select advanced
4. Select GeForce 7800gt tab
5. Check to see if SLI is enabled by clicking on SLI multi-GPU
6. Select Performance & Quality Settings
7. Under the Global drive settings..View...scroll and select Advanced settings
8. Under the settings window, scroll down until you see SLI rendering mode...
9. If it is under single-GPU rendering mode, then click to choose autoselect.
10. Click apply
You should be all set.
This solved my earlier problem..For some reason, after installation, although I enabled SLI mode, the advanced settings still selected single-GPU rendering mode. I was puzzled for a while as to why my 3dmark05 scores were so low.
Good luck.
The book just said to put them in and put the bridge on. The little sli led came on, too. In my settings it was on single gpu so i put it to multi-gpu since there was no autoselect. i'll do 3dmark 05 and let you know what i get
wtf?!? Is this guy serious?
3dmark 05 was between 11000 and 12000, i think thats normal. thanks for the help everyone :D
