Seems like system is windows 10 stable under 1.32V with an adaptive setting letting it spike up to 1.45V under load which I understand from intel's specs of voltage and multipliers means that it will always target a 1.45V with that 50x multiplier.
When I manually set it to say 1.42V and vdroop enabled I see load voltage plummet to 1.306V. Prime crashes instantly in this scenario.
So it appears I have a board without a happy medium over CPU overclocking. I either run high v idle just to get a proper load V, or run a low voltage adaptive and hit 1.45 under load. Both are pretty undesirable in the sense that I have a feeling my 5.0ghz required speed lies higher than 1.32 and less than 1.45.
Anyone with a similar EVGA board or something without a LLC setting (I have a Z270 classified) playing around with Kaby Lake 5.0ghz?
Am I good with just accepting that it will go balls out on voltage for load?
