7600gt Vs X800xl
SoundBlaster
I know X800XL doesn't support SM 3.0 while it is a good performer, how it is compared to 7600GT in terms of performance where it takes the advantages of its higher GPU and memory speed to achieve the best performance the bus width of 7600GT is 128-bit and the latter takes the the advantages of 16 Pixel Pipeline and 256-bit bus width? at which case the advantage of 256-bit will appear ?
the 7600gt and the x850xt are on par so the 7600gt will run faster than an x800xl
The 7600 GT also features shader 3, and also has transparency AA. The x1800 XL has neither.
The ATI cards have Adaptive AA which is essentially the same as TAA. In fact, the performance setting for AAA more evenly distributes samples across the scene for a more noticeable effect than the perf. profile in TAA. The quality setting for both implementations use super sampling across the entire scene which drops performance significantly though.
The X800XL was roughly analogous to the 6800GT in its day (wins some, loses some - rough equals).
In 'Oblivion', FiringSquad's tests show the 7600GT absolutely SPANKING the 6800GT.
Firingsquad said:
We didn’t expect the 7600 GT to come close to even matching the GeForce 6800 GT in performance, but in our tests today it not only equaled the 6800 GT in performance, it outperformed it by a double-digit margin. When the GeForce 7 first launched nearly a year ago, NVIDIA was quick to boast about GeForce 7800 GTX’s enhanced pipeline efficiency, claiming that the 7800 GTX was 50% more efficient on a clock-for-clock basis than GeForce 6. Based on our results with Oblivion today, that figure certainly sounds believable.
So...yeah, I'd say the 7600GT is the better card by a long shot.
7600gt no question. x1800xl is a different story...but it's still priced too high to compete with the 7600gt.
Wooooo this is very good news as i'm looking at getting a 7600GT to upgrade from my 6600GT which is really showing it's age trying to play Oblivion with decent quality on my 17in lcd.
the 7600 core is newer and to me it seems a bit faster than the x800xl overall.
for the money you just can't beat the 7600gt or the good sub-$200 deals on the x850xt right now.
the x850 pro,x800xl and x800pro and the like are still good cards as are the 6800s and 7800's however with newer cores being out - for an upgrade i would look to a newer design .
i'm still running a x800pro in my main box but eventually i'm going to replace it with either a x1800xt or 7900GT of the 512mb clan. unless i stumble on a super deal on one of the older cards that is. :eek:
