7600GT to HDTV
HalfBaked
Hello, I want to connect my PC to my TV using my 7600Gt's "VIVO" cables that came with the card. Im trying to make it so I can play movies I have on my pc, in good quality. What do I need to do yet, I have this cable in the back of my card ... I am out of ideas
My tv is a http://www.magnavox.com/index.cfm?event=main&cat_id=1&subcat_id=3&product=98#
Any ideas?
You could use a DVI-to-HDMI cable for a straight digital hookup. If you must use the VIVO cables, just grab 3 RCA cables and connect to the Component Out (Red, Green, Blue connectors). You could also use a DVI to VGA adapter and then use the VGA input on the TV. Heck, if you're lucky, such an adapter came with your card (I have like.. 6 of these things layin' around from cards I've purchased...)
