7600gt sli
sinbad
hi
if i got 2 7600gts running in sli compared to the just one i have now what would the performance diference be in games. what single card would you compare it to in the nvidida range ( taking into account that card running dx9 games)
thanks..
It wouldn't be worth it. Just buy a better single card.
A 7600gt sli might be as good as a 7900gs ? Somewhere around there I think. Thats if the game is actually coded to utilize SLI of course.
Probably along the lines of a 7900GS. Worth it if you can get the other 7600 for cheap, like around 50$ or so. But considering that you can find new 7900GS for around $99 after rebates... You'll have to weigh your options.
Two 7600GT in SLI is roughly equal to a single 7900GT. However if you already have a 7600GT, don't bother continuing on and buying another 7600GT for SLI. Use that money toward the x1950Pro ($137) or x1950GT ($115), which perform better than 7600GT SLI.
thanks ok probebly not worth it then.
does anyone know the best series 8 card i would be able to get with a 480w atx psu and its price
thanks..
What 480W do you have? Like model and manufacturer? And how long have you had it?
Also, list the specs of your PC.
dude if your gonna buy a 8 series only buy 8800 and up, 8600 suck fucking balls! just buy a new psu too
