754 Mobo Reboot Cycle w/ sptd.sys
Niksa
I replaced my old mobo with this one: http://www.newegg.com/product/product.asp?item=N82E16813185057
I just installed it but I'm having trouble loading windows. Now I can get to BIOS easily enough, but when I get to windows loading screen, I get a blue screen error for a fraction of a second and it would reboot. Same thing happens for safe mode etc.
I can't freeze the screen long enough to read the error, but when I'm in safe mode and it's loading files individually, the last one to load before it reboots is sptd.sys I can cancel the loading of sptd.sys but then it still reboots anyway.
I read some info about sptd.sys and daemon tools, but I'm not sure this is my problem since I never had this error before replacing the motherboard. But if it IS daemon tools, how can i get into DOS to delete daemon tools if I can't boot in safe mode? :confused:
In any case, since I've never had this problem before, isn't it more likely to be something incorrectly set up with the motherboard since that's new?
I can't get to that part because it reboots before I can load windows. I can't get safemode working either and I can't access DOS (WinXP) to diagnose anything like that. Do you have any suggestions to work around this?
Download the memtest86 .iso file and burn yourself a CD and boot off of the memtest CD. Also works on floppy.
www.memtest.org
www.memtest86.com
Either one of those works great.
