750i FTW question
Hi,
I am looking into buying the Evga 750i FTW. Do you guys reccomend this motheerboard or should i go with something else?
I`m just scared because i saw a lot of negative threads on the 790i FTW.
Also have another quick question=) I have an older Intel BadAxe2 motherboard and on the Intel site it says this mobo only supports 1.8v-1.9v memory up to 800Mhz. I gues i can not run any memory at 2.1v on this mobo?
thx in advanced for help.
Do you want SLI for sure ???
If not, then dump that WTF mobo and choose something from the P35-P45-X48 line. ;)
If you have an option for Vdimm higher than 1.9V on that BadAxe2, then use it.
While overall I really like the board, it's probably not the best choice if you're not going to sli. Though if you are, go for it :D
