Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
That was a really good call!
I went to the store this morning and bought another pair of Corsair SP120 fans. Put them inside the case as you suggested but had to cover the bottom with a rag to prevent the fans from sucking air from inside the case...now it's OK
I have a couple more intakes in the bottom of the box should i had a third intake fan?
