Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
under control panel, go to 'regional and language options'
select language, click on details
under settings, click add
select spain from the dropdown menu
now ur gonna have a little blue box on ur taskbar that says EN
click that, and it should let u change to spanish
keyboard should work now, keyword being should
You probably have to set language options for the keyboard.
Go to Control Panel, then Regional and Language Options. Click the Languages tab, and now you have to add the Spanish keyset. So click Add..., then you can select an Input Language. I see a lot of Spanish in there (for the major Spanish-speaking countries). And then select your keyboard layout (Spanish I guess).
Now you can switch between the English and Spanish keysets, maybe.
