Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Why to the motherboard i'd rather have it connected to the PSU, Not sure where you can find one but it wont be hard most of them come with that plug and a adaptor.. To plug into the motherboard check some out @ www.newegg.com
Hey i need to buy one blue LED case fan, but it is 120mm NOT the standard 80mm, this will go in the front of brand new SilverStone "nimiz" case, But I could find any 120mm Blue led's at newegg ? Anywhere else ?
