720BE unlocked max temp
Cygna
Hi there,
I'm running a 720BE with the 4th core unlocked at 3.6GHz with idle around 40-46 and load 55-57C. I read that the max safe temp for the 720 is around 70 at load. The question I have is does the max temp change when the 4th core is unlocked? I know the 955 max temp is in the 60s, which is why I asked.
Thanks in advance.
