TheLAWNoob
- Jan 10, 2016
Hi, I have a pair of R9 290 with EK blocks connected in serial with a no name brand chinese pump at medium speed. Have EK Supremacy Evo for i5 6600K and a 480mm slim rad from DazMode. 1400rpm fans.
Room temp 20-24C depending how long I've been gaming. Water temp unknown, but according to martinsliquidlab I might get 15C delta (water temp - room temp) with my setup.
Loop goes rad>pump>cpu>gpu>gpu
1st GPU: core 62C, VRM 80C (water goes VRM then core)
2nd GPU: core 70C, VRM 99C (water goes core then VRM)
I suspect I'm not getting enough flow rate since I have set my shitty pump to medium speed (full speed too loud).
If I get the EK parallel bridge, will that be a lot better since it will greatly reduce restriction and feed both GPUs with same water temperature?
