MelonSplitter
- Aug 6, 2006
When running Orthos my max temp reaches about 70C. Do you think this is to hot?
The MX-1 paste that comes preapplied on AC heatsinks is equally good as AS5. Stick with it.kill4killin said:problem number number 1 is that you used the stuff that came with the Arctic Freezer. Get some Arctic Silver 5 and put just a rice sized dab in the center of the Processor and place the heatsink on and give a little twist from side to side and tighten it down. See if that helps. If not, you may want to check how even the contact between your HS and processor is, it may not be getting good contact and causing higher temps.
Arcygenical said:Well, technically... Coretemp is more accurate, so by "using a different program" you're just ignoring the situation...
its not that the other programs are wrong, its just that core temp reads a different sensor (internal CPU)TheRapture said:And where is the documentation that proves it IS more accurate...? On my rig using coretemp also shows about 10c higher than ANY other program, I doubt ALL of the other programs are wrong...
