Howdy.
My two yeard old overclocked barton 2500+ with 9800 non-pro is on it's lst legs now. I'm looking to upgrade just the following things:
-mobo (i think abit s393 nf4, i think the model is AN8)
-cpu (hopefully a64-3500, and I'll clock it hard)
-video card... thats where I need advice.
I do not want to exceed US$700 for those items. I already have DDR500 memory, 500W decent PSU, high performance watercooling for cpu and gpu, etc, etc.
I was holding up with the upgrade until new ATI cards became available, so I have good choice.
I have decided that I want a single vid card (not SLI) , pci-x. the obvious choice would be 7800, but that might exceed my budget. I understand that new ati x1800 performs nearly as well as 9800, is that correct ? That would be my preferable choice, as could reuse my peltier/water block to run mad gpu clocl speeds (assuming bolt pattern is the same as x9xx)
What do you guys/gals think ?
Would it be better to go with slower CPU (like a643200 or a643000), but 7800 or better cpu (a643500) and get the new ati x1800 ?
Thanks in advance,
Mops.
Thanks in advance,
Mops.
